Hey all, been slowly fighting this issue since May 2020, now going on 6 months I'm just over it. 2006 5.9 common rail. 6 speed manual trans. Smarty 90hp tune. DAP 75hp SAC remans.
Backround- started getting a clatter noise going down the highway with or without load. Definitely coming from engine. 2 weeks later cylinder 3 comes loose, scores cylinder wall with about a .030 groove. Time for rebuild.
I rebuilt the engine myself, all clearances look great. Head rebuilt at a reputable shop. Double/triple checked myself every step of the way. Injectors were sent to DAP for testing during rebuild process. They replaced 1 solenoid. Only issue found.
Among start up, it purred like a kitten, no issues at all. About 1500 rpm I have the exact same noise/clatter I had before it blew up last time. Is more noticable when engine is at operating temp. My first thought was injectors, back to DAP they went. All check good.
-Double/triple checked valve lash.
-push rods are straight.
-new sensors ( crank pos, cam pos, IAT, MAP)
- scoped all cylinders when injectors were out, no scoring. But some carbon build up.
‐idle rail pressure 7600psi
-unplugged fuel regulator and pump makes 27kpsi.
- capped fuel rail 1 cylinder at a time, could not determine if knock was present due to misfire.
I plugged in an oscilloscope and each cylinder is consistent with the others, but there is 2 injection events, do these have pilot injection?
Does pilot injection stop after a certain rpm?
Does anyone else have pics of the duty cycle and duration of their truck with an oscilloscope?
TECH SPECIALIST
Set your trigger level on the scope, then set it for single sweep (aka "norm" on your scope), fire it and snap a pic of each injector's waveform...
There are 2 events at idle and possibly a 3rd, would have to go back and look at my tune but pretty sure its just 2 at idle. the 3rd event is in & out depending on load.
I suggest getting a data logger attached to the obd port, preferably a good one that can log all the engine sensors and log the event. If you can get timing, rail, crank, cam, IAT & CT that would be good...
Steve, first of all thanks for the quick response. Friend of mine brought the oscilloscope over, maybe I can get him to come over again soon. I looked at all 6 injectors, and all fire the with the same wave form. Also all 6 have an intermittent 3rd event at around 1500 rpm. Which happens to be when I get my knocking clatter sound. This is done with no load. Currently I pulled the ecm off and going to have him reflow all the solder joints inside. Once we have that done I will post updates and more pics of each cylinder.
TECH SPECIALIST
stop... get the ecm back and reinstall it. get a data logger setup and log data. for all you know it could be a bad sensor causing this.
Reactions: rghavana
