1 - 17 of 17 Posts
Personal preferences aside this is what I'm ordering.
SLT drw 4x4 6.7 cummins
Snow plow prep
Protection group
Cold weather package
Luxury group
Dual 220 alternators
6spd manual 3.73
Fog/clearance lamps
17" aluminum wheels (would like 19.5 but not available)
Anything I'm missing? Don't care about bells and whistles nav, heated seats etc
Need 5K payload shouldn't tow more than 20K obviously not both at the same time...I'll do after market gooseneck and ball...Just wanna make sure I'm not forgetting something practical...
JJ
· PA Cummins
You will be getting 3.42 rear ratio with the 6.7l cummins.
He can order any ratio with the dual rear wheels.
· PA Cummins
Yea. I thought I hit the preview button, as I wanted to go and look at the OP specs again. Then I realized that I posted it.:confused013:
Now, if only we could order the 3.73's in the SRW!
Not with his set up.
Discussion Starter · #9 ·
No worries that's what the edit button is for, Ive posted some bonehead stuff because my fingers work faster than my brain lol...
And you are correct had i gone SRW I can have any gearing I want as long as it's 3.42 :)
JJ
· PA Cummins
Did you consider the rear air ride?
Snow plow prep
Protection group
Luxury group
6spd manual 3.73
Fog/clearance lamps
JJ
· PA Cummins
Yea. I would go with the 3.73's. Less stress on the clutch when trying to pull out. As a comparison, my '03 with 3.73's, 6 speed and running 305/65x17's, I'm turning 2000 rpm @ 70 mph. Tires are about 32.6" in diameter I think. If I could get 3.73's & G56 in a Laramie SRW, I'd be ordering one today!
I found that in my 08, however with the places I tow WV,TN,NC,VA,GA I don't wanna find out the 3.42 doesn't cut it.
I'm hesitant starting with the 3.42 and swapping later.
JJ
Snow plow prep
Protection group
Luxury group
6spd manual 3.73
Fog/clearance lamps
JJ
May want to research what you're getting in the snowplow prep package. I ordered it and the only thing that I can see that I got for my money is a skid plate. For only a skid plate there are cheaper ways to go.
Discussion Starter · #16 ·
I can do that, when I did the build sheet at the dealer 1st one was with items individual then he clicked snow plow prep and saved me money that was the only reason it's on the list...
JJ
1 - 17 of 17 Posts
