I am only getting 11-11.5 psi of fuel pressure at the pump with the air dog 150 is this normal or low I hear guys get around 15-17 usually, i have rechecked everything no leaks anywhere, its just a constant 11psi at idle or WOT should i be worried or just leave it be? Do you think my fuel filter is getting clogged already I've only had the system on for a week maybe two
I wanna go fast...
I would not be worried about it if it stays constant...do not let it go below 8psi though. Give Charlie a call at Airdog and he will fix you up with a pressure spring if you really want more psi.
I wanna go fast...
And no, your filters should not be clogged.
i agree as long as you have good FP at WOT then i would leave it alone :thumbsup
Ok yeah it doesn't move at all when the go pedal is mashed to radiator so I am gonna trust you guys and not worry about it
