:agree2: Sounds like you need a new alignment shop. Unless your axle is actually bent or something, they're not doing their job. By the way, you CAN do your own alignments and get really, really close (if not dead on) to the specs.it seems you are outta alignment. turn the end of the tie rod in... this should be an alignment shops job....
What to do? ..... Move to a different town! :hehe: (I crack myself up!).... this is the best alignment shop in town
Mike - Came up with your method on my own, out of necessity, when installing Thuren Cross Over Steering drag bar and tie rod. Had to drive 300 miles after the install and needed it close to proper alignment!:.... By the way, you CAN do your own alignments and get really, really close (if not dead on) to the specs.
Not a bad idea! I'm with ya on the measuring accurately to the outside of an M/T.... sort of difficult at times. I agree with you on the 1/8" thing too. I got that spec range from PavementSucks.com but 1/4" seemed like too much to me so I did 1/8" too.Mike - Came up with your method on my own, out of necessity, when installing Thuren Cross Over Steering drag bar and tie rod. Had to drive 300 miles after the install and needed it close to proper alignment!
Now, after 5,000 miles that feel perfectly aligned.... no uneven tire wear. So I assume it's right on.
One variation to you method. We took a can of red spray paint, close up, and spun the tires by hand while painting a thin line down the middle of the tire tread. More accurate to measure to the outside of this line than to the outside on an aggressive tread of an M/T tire. Also used 1/8" toe in. 1/4" sounds like a lot?
And doing it this way.... you end up with a racing stripe on your tires for a few hundred miles!
RJ
