1 - 14 of 14 Posts
I installed a NOCO Gen5x1 onboard battery charger last weekend on my 2013 2500. It worked nicely but last night, with truck parked and plugged in, I happened to see that the dashboard lights were on/cycling. Has anyone seen that happen before? Could it be because of the way I hooked the Pos and Neg cable from the charger to the battery? Should the Neg be connected to battery or to the chassis? I m also wondering if the Battery IBS has anything to do with this??
I can't say as to why your dash lights are on/cycling. I have 4.5amp Battery Tender installed on my 2017. I hooked the positive and negative directly to the drivers side battery and have not had any issues.
There have been some comments on here of tenders doing that - and some suspect it has to do with exactly where you connect it to the terminals. Do you have a pic and I’ll compare to mine?
Too late haha, I just moved the neg cable to the chassis. But I marked in the photo below where it was
Motor vehicle Hood Automotive exterior Automotive design Car
2015 Ram 2500, Longhorn Laramie LTD, 6.7L CTD
I'll have to see if mine is doing this as well. I've never paid attention.
Reactions: Lins
I thought it had more to do with where on the power side it was mounted but I could be wrong. If you still have issues let me know I’ll have a look at mine.
Well, I just had a look and it is still doing it. It is charging but when looking at the dash cluster, it is lighting up again
No problem with any of my BTs. I connect the pigtail to the battery clamp bolts and hang the polarized connectors by the grill. The BTs won’t charge unless they are connected correctly.
Discussion Starter · #12 ·
I've seen it before when I plugged in before the truck modules went to sleep. Now I wait a few hours or days and plug in using the seven way receptacle on the bumper...no more issues.
I suspect some type of electrical noise causing the module to wake up.
Video information
Reactions: jackvz
HVAC module behind glovebox is known to be one cause of truck staying awake.
Reactions: jackvz
1 - 14 of 14 Posts
