1 - 1 of 1 Posts
I have a 2006 dodge 5.9l we just installed the "airdog" air water sep, system with 70 lbs over stock injector tips. now the truck won't fire on it's owne. we were told we might have air in the system, so bleed it! ok, after bleeding everything,still won't fire. was told to dryfire to get running and the air would perg, from the injectors with either.. OK..did that the truck started.. ran bad and smoked..! not a little ALOT.. thick and black..! had to shut it down.. the fire dept was comming... said f-this.. took the injectors back out,and put the stock tips back on. with new o-rings,and seats. Now the truck still won't start on it's owne, but will start with either and run at 10% throutle and smoke bad with fluid pouring out of the exhaust. everything we put on the truck. Airdog 2 with the stock filter bypass tube. 70 injector tips we took back out, and still have the smoke problem with liquid out the exhaust, stuck injector or two??.. any Ideas????
1 - 1 of 1 Posts
