1 - 9 of 9 Posts
Trans before turbo.. you'll kill the trans if you get the turbo first and then you'll have a unexpected cost..
head studs should be on top of the list or you will be doing a head gasket before u know it. Also good idea to put in some gauges to h&s runs some pretty hot tunes.
with a 68rfe (guessing thats what you have and not a manual) i would definitely get a built one.. depending on what your end HP goals are there are a ton of options out there that will hold up for you.. Its going to be your most expensive investment, for sure, but probably the smartest one.
1 - 9 of 9 Posts
