1 - 10 of 10 Posts
1998.5 Dodge 2500 4x4
I finished rebuilding my 5.9. I had oil pressure when I first started the engine. Then noil pressure. I have replaced oil pump,oil pressure relief valve, oil regulator, oil cooler, new pick up tube. I still have no oil pressure. Any ideas.
Even though you may get help here, it’s best to post in the correct section.
Model year etc. This is in the 2019+ 6.7ltr section.
No it is not 2019 section. He is in right place. Put on manual gauge unit to see if you have no oil pressure or no reading.
Reactions: MustangDiesel004
Vendor Deluxe
Mods moved it here from there. Think about it.
Ya that was the first thing I did no oil I tried priming wielded nut on old pump oil didn't make it to valve train. I even tried pushing oil thru top of filter housing but again no joy. I trying to figure out what else to try.
I don't understand what you're trying to do there. Explain a little clearer. How are you pushing oil through the filter. Priming a wielded nut. ??. Best I can say is to take it apart and see what went wrong.
Ok I welded a nut on the old oil pump. And used a pressure vessel with a quart of oilseveral times about a gallon. And I was looking for anything I might have missed. And yes I'm just about ready to pull the motor out again.
You recon a plugged line or possibly oil gallery in the head or block?
Check that the oil pressure relief is not stuck open or that the spring is not crushed.
1 - 10 of 10 Posts
