1 - 2 of 2 Posts
just for the heck of I figured I'd ask because I think I know what the answer will be but will I have to lift the engine on my 98.5 24v to change the oil pan gasket and if so just what will I have to unhook so the engine will lift. Also will I have to jack the trans. while I lift engine just to give it some support?
I personally haven't had to do this (knock on wood).
I've seen this discussed a few times.
Appears some take it a little further than others.
Your about on track with your thoughts.
* Disconnect batteries
* Remove motor mount bolts
* Remove fan shroud bolts (Some remove the fan and shroud, I wouldn't)
* Remove trans mount bolts
* Lift motor (front & rear lift points) and jack trans carefully (in unison) keeping a close eye on fan/shroud
* Should be able to get enough clearance to sneak the pan out and replace gasket.
Hopefully someone with first hand experience will chime in.:thumbsup:
1 - 2 of 2 Posts
