1 - 2 of 2 Posts
I changed power steering pump now it seems oil is dripping between pump and vacuum pump is there a seal i need to replace
You can put brake fluid in instead of power steering fluid and it will help swell the seal and stop the leak. However if it is leaking alot this wont help and you will have to redo the connection
1 - 2 of 2 Posts
