1 - 4 of 4 Posts
you'll have to lift the motor several inches to get the pan off. It's gasket shouldn't be leaking though if it's never been off.
:agree2: most common problem on our trucks are front crank seal and oil leaking from breather tube onto side of oil pan may make look like oil pan gasket leak... there are a PIA to change or well from the looks anyways.. :thumbsup:
if it's leaking between the oil pan & bell housing, it's probably your rear main. mine walked it's way out and fell out when i touched it with a screwdriver....
1 - 4 of 4 Posts
