While I was doing an oil change yesterday I noticed some oil seeping out of the bottom of the turbo. It looked like it was coming through the fins. The intake was clean so it can't be coming down. So do I need to make an appt. at the stealership? I've had the turbo drill tapped and cleaned already so maybe its time for a new turbo?
it is the CCV. The dealer replaced mine 40,000 miles.
Just left the dealer, they are installing a new turbo in my truck - p2262 code 3rd time. Mechanic found oil in the intake side of the turbo. Told me that this condition is caused by a bad bearing in the turbo. Factory requires the turbo to be replaced if any oil is found in the intake side of the turbo.
Thanx for that info. Ill be calling tomorrow to see about a new turbo.
Thanks for the info
