1 - 2 of 2 Posts
I have a 01 dually auto and today I turned into my driveway and my dinger went off, my check gauges light came on and I had low oil pressure. I got out checked the oil it was fine so I started it back up oil pressure was normal then went back to being low again. I turned it off then restarted it and it work normal again. I think it might be the sending unit. Any help to what the problem might be would be great.
My brother-in-law once had a car ( duster ) that had a loose firewall plug, and sometimes when he turned left, the engine would die. Was really hard to solve. If i was you i would check the connections and check the oil again, is oil full of fuel, making it thinner and making the oil pressure actually BE lower. I hope that you find a loose wire, but it could be the sender .
1 - 2 of 2 Posts
