1 - 20 of 32 Posts
hello everyone
my first dodge an first diesel
trying to figure out the best oil filter and oil to use thats easy to get ,,i figured rotella oil and fleet guard filter lf1635,im not 100% sure if this filter is correct to stay in warranty ,, have 5333 miles on truck ,,any help greatly appreciated
thanks joe:confused013:
PS.hope im on right forum
Go Packers
Filters - Oil
I order all my filters for my 2012 from Geno's garage. I use the LF16035 for oil. I use Valvoline Premium Blue 15/40 engine oil. This is a great forum. Lots of smart folks here. Joe, welcome to the forum.
Mobil1 M1-403
Baldwin BT 7349, 7317,
Donaldson ELF 7349, DBL7349 Wix 57620,
Fleetguard LF16035
These are some of your choices for filters. Warranty wont be an issue.
As far as oil, any Qualified CJ4 oil will be good in 15w40 or 5w40.
Fleetguard LF16035 filter and Rotella 15w40 here, ran the stratapore filters and Rotella on all my past trucks....
Reactions: CTD&TDI and joembx
Donaldson--DBL 7349............Mobil Delvac 1300 Super 15W40
Reactions: joembx
Reactions: joembx
the LF9028 has not been tested for an over the road truck application, it's designed for standalone refrigerator units.
the best filter flow and micron rating wise would be the DBL 7340 hands down.
Discussion Starter #12
order
Mobil1 M1-403
Fleetguard LF16035
hey dodgetracker ,,are these in an order of quality ,or all good,,thanks
If a person changes oil every 5000 to 6000 miles, those filters would be a waste of money. You would have to risk/run extended change intervals in order for those filters to be cost effective.
Looks great, but with the 15k service on the new trucks, I wouldn't want to leave the same filter on for 30-45k....plus the LF16035 filters can be had for about $10 a piece if bought in bulk, vs the $30 for the extended life. The price makes it a wash.
Now it would be interesting to see how much of a difference the XL filter made on oil quality vs the LF filter with the same 15k change interval...
Feetguard
LF16035
Micron ratings
30 at 100%
25 at 98.7%
10 at 60%
And it's approved by both ram and cummins
Actually this is better prices then amazon
DBL7349 - ELF7349 - DB LUBE DONALDSON REPLACEMENT FOR REPLACED BY ELF7349 - Filter Products
DBL 7349 99% at 15 micron which is alot better then the standard mopar filter, synthetic element, and its $11.69 per filter. I bought 10 of them I think so I am set for a while.
Oh, now isn't that interesting...I need to do some more research on these
Donaldson
DBL 7349
Micron ratings
20 at 100%
15 at 98.7%
7 at 60%
I don't know if it's approved but it is the best full flow filter that I've seen. I don't think anybody should have a problem with warranty work.
Discussion Starter #17
just want thank everyone for all the info,alot of knowledge on these pages,i guess i made a decent choice with the lf16035 and found them for 11.10 at filter barn ,ill buy them 10 at a time for free shipping,,,, my next questions will be about fuel filters an differential fluid
thanks again joe
Go Packers
thanks again joe
Dodge Ram Cummins Mopar and Fleetguard Fuel Filters
I use the Mopar Nanonet fuel filters. 5 micron outer/3 micron inner filter. It is a 2 stage filter.
For the rear differential on my truck, I used Amsoil Severe Gear® 75W-90 gear oil. AMSOIL Synthetic Gear Lube - Gear Oil I choose Amsoil for the extended mileage between changes. Hope this helps.:thumbsup:
When I changed my rear diff fluid, I purchased 5 quarts. I used 4 full quarts, and a bit of the 5th one. My truck has a 11.50 Rear Axle
Reactions: joembx
I use the donaldson filters for everything.
1 - 20 of 32 Posts
