Other than the gasket, there isn't any part that could be worn out. If you need one, go for it.
I replaced that rubber fill tube gasket when I tabbed the kdp. It was only $5.00 from Dodge, should you need to replace that when you get the used part.
Thanks. Ordered from ebay for $35 +$10 shipping. The seller said that the gasket is good. I tried the parts dept at the local Dodge dealership and they didn't answer...I'm hoping ebay is cheaper than new.
I also ordered S&B Clamp-On Crankcase Vent Filter, 3"OD x 2.5"H - 1-1/2"ID w/ Rubber Top : Amazon.com : Automotive (S&B 26-0015JR) to go on the end. Hoping everything works!
Were you planning on putting the crankcase filter into the top of the oil tube in place of the original cap? Are you trying to vent excessive blowby?
