Some white smoke too. Just changed the manifold, turbo, value cover gaskets and water pump. Any ideas?
did you change the turbo itself or just the gaskets?
Oil out the exhaust could be the turbo shaft seal, or it could be coming from a valve or cylinder.
I changed the turbo entirely. It was running just fine before the extensive things I did. Had no leaks in valves/cylinders at all. Do you think it's the turbo?
pull the turbo off the manifold. if their is oil in the manifold chances are its got to be coming from the engine. if the manifold is dry, the oil has to be coming from the turbo
