FUEL
how do i reset the overheard? i sas oil change needed but it shouldnt need one for at least 2000 more miles. the oil was changed maybe 1000 miles ago. either way its not a big deal as im refilling her with amsoil synthetics monday, but the current oil looks and smells fine. just curious how i reset that darn console
It's been covered before...I think you turn on the ignition to "on" and pump the gas pedal 3 times, then turn the key to off. Someone else chime in if that's incorrect. I reset mine when I switched to amsoil at 10k...now at 15k it's never come back. Previously it had been going off about every 3-4K.
get in the cab & close the door
turn the key to start (right before starting the engine)
pump the gas pedal three times
turn the key to off and pull it out
that should do it:thumbsup
No seat belt needed. Just turn the key on, pump the fuel pedal 3 times to the floor, turn the key off and its done and gone.
