1 - 20 of 36 Posts
I got in my truck at work tonight to go home and this is what I saw:
Car Vehicle Speedometer Auto part Trip computer
Is this what you guys are seeing? If not, what are you guys getting in between changes?
The manual and the topics I've seen mention 7500 miles. I searched and didn't see any threads dedicated to this.
Pretty normal for a stock truck that doesn't work particularly hard. I usually saw from 2700-4200, from my daily driver, no towing. I got over 5000 once when I pulled a larger U Haul from Minneapolis to New Hampshire and back.
Go Packers
My last message came at 4,297 miles on the oil.
Sorry to hijack, but do you guys change the oil when the light comes on, or do you follow the owners manual recommendations?
Go Packers
You raise a good question. I change when the message appears. My truck is not deleted. I've read other posters who also state if your truck is not deleted, change when the message appears. Some may get close to the 7500 mile mark, but IMO, they are deleted or not much grocery getting with them, lots of highway driving, or towing.
Redneck, the only dumb question is the one you do not ask. Best wishes.
Reactions: NC4stroker
Every 10K miles--deleted. Makes it easy to remember.
That' what I'm doing. Also, I agree. Unless the truck is deleted, or worked hard it's not gonna make it to 7500 without regeneration breaking down the oil.
I get my oil tested from black stone labs to monitor spot fuel dilution and tbn I ran 10k last time and they recommended trying 12 k my light comes on about every 3500 miles
My truck is all stock...bought it with 35217 miles on it (oil change done before I took it home)....light popped on with 5,002 miles on the oil...just last friday. So it def is going to vary....
And got the oil analyzed by Blackstone Labs. Fuel dilution showed Trace...so I was really happy about that. Aluminum and Potassium were high though...they said it could be piston wear (aluminum) and faulty EGR Cooler (Potassium)....but they also said it is normal for these readings to be high from a newer emission system from these new diesels. So I am going to get it checked again in 5,000 miles and see if numbers drop. Everything else was fine.
Mine popped on this am 2300 miles after last change. ..it came on at 2500 last time...seems too soon? Should I change it again?
Change it. It can't hurt with all the problems your truck is having with the emissions.
Why is the interval so bad? Would dpf delete help?
Why is the interval so short...thought it was 7500. Dpf and egr ?
I dunno. You've had all sorts of crazy stuff going on with your truck. The dang computer is probably all confused.
Ha...yeah...but 2300 is not many miles
Yeah, your oil change interval is decided by the computer, basing itself off of, idle time, passive re-generations, and forced re-gen by dumping fuel during the exhaust stroke to get the your EGT's high enough to burn the soot.... So unless you're driving a lot of highway or working the truck pretty hard you're going to see short oil change intervals
Deletion of DPF filter and EGR cooler and valves ultimately allows you to decide when to change the oil, I may still follow the 7,500, might stretch it to 10k, but if I do 10k I usually change both the fuel filter and oil filter at 5k, but I can probably do 10k for the fuel filter, always air on the side of caution.
I did my first oil change at 3,500 and then a second at 10k after I deleted around 6k... can't wait to see some cleaner oil come out of this thing.
Wow...amazing how saving pollution uses more fuel and oil and money
The owners manual says every 6months or 7500 miles, or if the indicator light comes on change it...
1 - 20 of 36 Posts
