1 - 10 of 10 Posts
have 2011 6.7 installed spinner 2 centrifuge was rather fun required battery relocation some problem solving and piping but result is much cleaner oil would be interested to see other installs for ideas. has run 1000 mi since install am sending oil in for testing in another 5000. what are others getting as far as change intervals
I was just considering this over a bypass filter for my truck... please post pictures.
have images but too big for fourm will get them added tomorow
install was not easy its a gravity drain system @ 1gpm processing used 3/4 in drain tapped into spare frost plug just below filter that drops into oil pan, then utilized tap from top of oil filter to feed it, 3/8 line feed, also this unit needs positive air to press for float drain i drilled and tapped into boost tube post turbo have used similar set up on my heavy equipt for years would highly recomend it
Pics please
I'm looking at doing that two but need pics to see how!!!!:banghead:
Reactions: Mutch79
Your oil change interval will depend on how comfortable you are with the percentage of the soot in your oil before you change it.
I run a Frantz By-Pass Oil Filter & at 5k my soot level is .1%. The question is what is a safe level of soot? Everyone has their own opinion on this.
I came up with mine by comparing it to a gas engine car.
My wife's Honda Fit with a Mobil 1 oil filter soot level was .2% at 5k. So for me .2 % or less is my limit, ie I change my oil at 5k.
SB
1 - 10 of 10 Posts
