1 - 4 of 4 Posts
Piggy Piggy
I need a little help on off set,I need to keep my tires under my fender.I dont want em to stick out do I need to look for a postive off set of negtive ?
U need positive offset, I would say around + 15 offset and 6.00 backspacing..
MX is right. I'm running 325 Nitto's with the stock wheels and I rub when the wheel is pinned either way. I have been dealing with a couple tire places and the consensus is I need to get a wheel that is a +15mm offset and a minimum of 5.6" Backspacing with 305's to avoid the rubbing. So far this is the best answer I got. So if anyone has a better one...................................
Your factory wheels have a 43mm positive offset, anything else and the tire will start to stick out farther. Check out 1010tires.com and under the tech section there is a wheel offset calculator.
1 - 4 of 4 Posts
