1 - 9 of 9 Posts
Per my information below, I have a 2009 3500. It came with an OEM brake controller installed already. I have been towing a gooseneck trailer around empty off and on and everything seemed just fine with the trailer brakes and controller.
I loaded a 5000 lbs ISO container on the trailer the other day. Now when I brake, the trailer brakes do not function and the light that indicates how much brake pressure there is stays green. I can manually apply the trailer brakes from the brake controller and it works fine and the light gradually changes from green to red. It just isn't working when I use the truck brakes. I tried disconnecting and reconnecting the pig tail as well as turning off the truck and restarting it.
Anyone have any idea what might be wrong?
Master of Mayhem NASFIG
could be a ground issue with your trailer ball mine sometimes does that till it rubs good
My o4.5 did the same thing. Make Sure You Didn't blow A Fuese, Check The one for the high mount center stop light, it has a seprate Fuese.
Thanks for the help. The ball should be plenty grounded. On the drive to pick up the ISO container the brake controller was working just fine. I switched the truck off to load the container and after it was tied down I started the truck and drove away. At the first stop I quickly found out the brake controller wasn't working with brake peddle pressure.
The fuze sounds more plausible so I will check that tonight. Thanks again.
did ya try adjusting it with any success. if it has a blown fuse then i would think it wouldnt work at all. mite try your trailer tow fuse tho
Yep, tried adjusting as I know with the added weight it would take more ajustment, however, that proved pointless. When you say trailer tow fuse, are you refering to a fuse on the trailer or the truck? If on the trailer, I don't believe that would be an issue simply because if I use the manual slider on the brake controller, I feel the trailer brakes working and the LED on the brake controller changes colors gradually from green to red. It's just not working when I depress the brake pedel on the truck.
I had the same problem with mine and it was a grounding issue with the trailer. I just ran a extra wire from the trailer and grounded it to the truck. It was just one of the trailers I have but I got tired of the brakes not working when I needed them so i ran that wire.
Discussion Starter #8
I'll check the fuses first and if that doesn't prove fruitfull, I'll try the ground wire and see if that helps.
not sure on the intergrated trucks but on mine in the fuse box it has a 50 amp for the trailer tow pkg which has the brake controller power tied into it
1 - 9 of 9 Posts
