1 - 4 of 4 Posts
So I went to start my rebuild. And nothing no click or anything. Proceeded to just jump the starter and that worked fine. So I wired up s push button start to send 12v to the yellow wire that goes to the starter. Not sure what went wrong but turning the key no longer sent the signal to starter. So I wired it all up turn the key to run and press the button and my alarm goes off. But if I turn the key and push the button it does not. Is there a way to disable or fix this? Any help is appreciated. Thanks!
· Admin/Mod
:confused013: :banghead:
Don't get it.
Did you try to test the wire to see if it getting power from switch.
Is there a fuse for the circuit?
1 - 4 of 4 Posts
