I ran the key cycle today to see if I have any error code and did not understand what I got. P PCU, P DONE, P ECU,P DONE. can you guys make any since of this.
Discussion Starter · #2 ·
no one has any ideas.
it means you have NO CODES when it says done, it's done looking for codes, and none came up. when you do have codes it will say the code, then say done
What does the P ecu and P pcu mean?
ecu is the engine controll. pcm is power controll??? i'm not sure what they're called, but it's the computers
I will check my factory service manual and see what it says.
Mopar1973Man.Com
He's right you code free...
The P PCU is the Powertrain Control Unit AKA: Powertrain Computer Module.
PCM
The P ECU is the Engine Control Unit AKA: Engine Computer Module.
ECM
And communicate over the CCD network.
CCD Data Bus
Here is about the error code reading you done...
OBD II Error Codes
