Hey folks,
I am new to the board and hope you can help. 02, 138,000 miles. Automatic.
A couple of times over the past seven or 8 months I have experienced the following. Between 45 and 60 mph, in overdrive with the converter locked up just after decellerating,I start pressing down on the pedal and nothing happens. Engine speed stays the same,no accelleration occurs....no registration that the pedal has been pushed until I mash it all the way down and then it down shifts and all is normal again.
Then the other day on a 600 mile + journey,it happened nearly a dozen times.
No loss of power, no hard starts,no trouble codes,no tach fluctuations.
Engine is stock with a Banks big hoss 40 hp controller and a magnaflow 4" exhaust. Both of which have been on the truck for 110,000 miles.
TPS maybe????
Any way to check for an intermitten problem like that....or anyone of you experienced the same?
Thanks,
Doug
TPS maybe????
Thanks,
Doug
