Driving home my truck died with no warning. No check engine light no sputtering just silence. First thought was VP44. Scanned the truck with a Snapon scanner and no codes. I have fuel pressure and I have fuel to the VP44 but no fuel on the other side. Pulled the pump and sent it in to Industrial Injection and the pump is perfect. The VP44 did have 2 codes, one was crank position sensor { i think they ment cam sensor } and the other code was ECM. If the cam sensor was bad would the scanner still show rpm's? Does this sound like the ECM took a dump?
Any thought's????????????????
