i'm just wanting to learn some stuff and here's my question. I would like to eventually put compounds on my truck. Now i know that i would need head studs and a better head gasket because the stock studs and gaskets are good up to 40psi. 40psi is about the edge before stuff starts to go :lol3: So if putting in head studs and a gasket will hold quite a bit more boost pressure, what more does one gain from having the head o-ringed? is it just one of those reassurance things or what:thumbsup:thumbsup
I run 58psi without studs and o rings.I need to get it done
Go for Broke
studs and O-ring will hold 80+psi of boost
if your pulling the head then have it o-ringed,..... it's a big job to do it again
so what would just studs and a gasket hold? i prolly will have it oringed whenever the money is saved up i'm just curious:thumbsup
Go for Broke
i blew mine at 45 psi with studs...some hold to 50psi and some don't....it's a crap shoot
it's only about $300 to O-ring it and if you have to pull the head then do the o-ring at the same time :thumbsup
