1 - 3 of 3 Posts
So I’m swapping a 12 valve into a Chevy and I have a nv5600 high output but I got an engine plate from a 2003 g56 will a nv5600 clutch and flywheel work with it or are the starters and flywheels different what should I do look for a 2002 nv5600 engine plate or use the g56 I just don’t. Want clutch problems
Tire Wheel Automotive parking light Vehicle Car
'94-'02 are all the same, but you may need the starter spacer. Not sure about that '03 one you have.
Mountain Man Customs
2003 would be an nv5600, not G56. The engine bolt pattern is different than your 6bt but it will work if you leave 2 bolts out which don't line up.
1 - 3 of 3 Posts
