1 - 9 of 9 Posts
R There Any Six Speed Guys Out There That Have Delt With 1 Starting To Go , What R Some Symptoms.
Tech Specialist
whats going on???
hard shifting, grinding gears???
since you have an upgraded clutch I would first look at the hydraulics. had the same issue on my yoda, ended up wearing out 1-2-3 syncro's cause the slave cylinder went out.
:agree2:
I lost 3rd gear syncro. No 3rd gear. Lots of grinding. If somethings done its done.
IMO....the NV5600 is a hateful transmission from the ding ding.
I Have Replaced The Slave Twice . Do U Know Of An Aftermarket Adjustable Setup ? When I Shift Out Of Second Somtimes It Doesent Want To Come Out Of Gear Or It Will Easily Fall Into A Lower Gear During Normal Shifting .then When I Get On It 4th And Fith Dont Want To Go In Gear.
Tech Specialist
sounds like either 1, your syncro's are shot, or your hydraulic system is going the way of the dodo bird.
Thanks Guys, I Will Look Into This W/ Valair Or Southbend. I Need To Get This Fixed Before I Drop In A New Turbo. As For The Syncros Do U Know Any Good Trans Guy Around Tomball ,cypress Area.
Don't know of anyone in this area that can work on the NV5600. Try Relentless Diesel in Willis, Hotrod Diesels down in Texas City or Northwest Diesels off of 1960.
MikeyB
Discussion Starter · #9 ·
Thanks Again
1 - 9 of 9 Posts
