Ouch!!! IDK what could cause it but who ever did the work should stand behind it, I hope...
Are you serious? I have over 900 ft lbs on mine..the NV5600 is rated MAX at 650 lbs ft of torque, what's your truck make max?
800 lbs ft will walk right through 6th gear and set it up for failure
do you tow heavy?
what tranny lube and how much?
any PTO cover coolers on the tranny?
stock NV5600s run too hot towing heavy
I have never heard of 5600 breaking that much, sorry to hear that manEither way guys I am getting really F'n pissed about this, 3rd complete rebuild in a year now! I am seriously thinking about swapping to a NV4500, hell of a lot cheaper! My buddy who pull said the gears are weak in the 5600's so that is why he uses a modified 4500, he was busting input shafts until Valair got him one of their made in the USA billet ones, now he hasn't had any problems. I don't tow that much with mine so I don't really need the extra gear spread to be honest. Any thoughts guys? I agree with the 550 TQ thing, sure, but that is probably on stock EVERYTHING. I think once you up the clutch they are much much more capable from what I have seen and read. My truck is no where near a heavy modded truck so I can't see why it keeps crapping out on me!
Anyone on here think this shop I used just really doesn't know how to work on the 6 speeds? It seems that way to me because other than clutches i never had a problem in 4 years, now i'm going for round 3 in less than a year!
I disagree... with the fully splined main shaft and a new 5th gear, the 4500 is more reliable than the 5600 IMO.5 speed is cheaper to fix, but with alot of hp will tend to break more often
Notice i said stock to stock, of course a fully splined main shaft and (new) 5th gear its going to be great and yes if guys build them they will last, but i have seen alot more nv4500's go then 5600's. I have a 4500,5600, and a G56 and have had less issues with the 5600 then any of them, i cant keep the g56 together and the 4500 is always having problem, the 5600 is in the 4wd and has been hauling 40ft PJ trailers loaded with 20 round bales for a while and seen a few sled pulls and see alot of low 13 second runs adn still no issues, just my experienceI disagree... with the fully splined main shaft and a new 5th gear, the 4500 is more reliable than the 5600 IMO.
and people seem to actually build them and get them to last.
I think lugging the truck along for so long in 6th is what killed it. sad to say, but the 5600 doesn't like to haul heavy in 6th. Buddy of mine lost 5 of them in the span of 2yrs hot shotting.
I would swap a 4500 in it and never look back. I've had 3 4500 trucks and two 5600 trucks, I'll take the 4500 every time
