1 - 4 of 4 Posts
alright i would like to start the long process of converting my 47re into a nv4500 5 speed handshaker:thumbsup first off i'm up in laramie, wyoming cuz im in school. so would anybody on the cumminsforum know any auto salvage places in the nearby region that would have a wrecked dodge with all the necessary components? or would anybody on here have something that they would think about selling me?:popcorn::popcorn::popcorn:
TECH SPECIALIST
I should be finished with my swap today if the damn rain will just stop for an hour or two so I can get it wired in.
Here is a list of exactly every part you need. There's no need to get a donor truck or anything like that.
  • Transmission
  • Bellhousing
  • Shifter, boots, and shifter trim console. There is also a dash pocket that goes in place of the auto cup holders - This is obviously not a requirement.
  • Clutch and brake pedal. Just pedals, they slip right onto the auto bracket.
  • Clutch master and slave cylinder
  • Clutch
  • Flywheel
  • Flywheel bolts - these are longer than the auto flex plate bolts.
  • Pressure plate
  • throw out bearing
  • clutch release fork
  • new input gear for your transfer case
  • front driveshaft from a 5spd truck
  • transmission soft mount on the cross member - The auto is different.
I'm trying to think up all of this off the top of my head. I'll look everything over when I go back out there. I'll make sure I didn't miss anything that you will need.
And that's it. It may look like a lot of parts but it's really a very straight forward conversion. I've never done anything like this before, and I have been learning as I go. This swap has not been hard at all.
If you have it out, you might consider staking the nut on the countershaft so 5th gear won't walk off. This is the only problem with this tranny.
sweetness where did ya get the tranny from? i'm in the laramie wyoming area right now so i don't know of anybody that would have like a salvage nv4500.
1 - 4 of 4 Posts
