So i recently picked up a g56 from an 08 ram 2500 with the 6.7. I got everything from the adapter plate on the back of the block to the transfer case, what I am looking to do is replace my nv4500 on my 5.9 12valve with the g56. Any help would be appreciated and I also have some questions.
- will the adapter plate from the 6.7 bolt onto the 5.9?
-Will the flywheel off the 6.7 bolt onto the 5.9 crank?
- are the starters the same?
If yall have any ideas or input on this swap id be happy to hear it
Mountain Man Customs
Probably not your B series flywheel. You'll likely need to use one specific to whatever G56 specific clutch kit you use.
