1 - 2 of 2 Posts
So i recently picked up a g56 from an 08 ram 2500 with the 6.7. I got everything from the adapter plate on the back of the block to the transfer case, what I am looking to do is replace my nv4500 on my 5.9 12valve with the g56. Any help would be appreciated and I also have some questions.
- will the adapter plate from the 6.7 bolt onto the 5.9?
-Will the flywheel off the 6.7 bolt onto the 5.9 crank?
- are the starters the same?
If yall have any ideas or input on this swap id be happy to hear it
The G56 bolts to the 5.9 adapter plate and uses the same starter. I went with a single mass flywheel and OFE clutch set from South Bend. I'm assuming (knowing the definition) that a 1st gen conversion would be pretty much the same as a 2nd gen.
1 - 2 of 2 Posts
