How hard is it to swap a nv4500 into a 1st gen? Is it a direct bolt in except do mounts? Or would I have to get longer/shorter driveshafts? And tcase?
the adanced adapters is all bolt in if you have a 4wd and the correct input shaft except for cutting the floor i used the AA kit it was a breeze
Theres two different styles of input shafts on the NV4500 so to work with the advance adapters kit the splines must be 2 3/4" long
