ok i have the dodge listed below with all of the up grades and smarty on lvl 7 with torque on 6 timing on 4 and duration on 4 and well i noticed today that cruising at 60 if i let off of the throttle it will white smoke, not really blue but i cant really tell from my mirriors, ok now thats a problem, another is on the inside of my ic boots and tubing i noticed a lil oil or what i think is oil, is this normal?? has anyone else had this problem? ive checked my oil and my antifreeze and they both arnt milky so im lost here and i dont know what to do and a lil scared cause ive only put about 1000 miles on it since i finished the build and installed the twins. :(
If it is not using oil, you have nothing to worry about. Just keep a watch on the oil level.
but what about the turbos?? i dont want to ruin them
U could possibly be burning oil left on the cylinder wall due to insufficient piston oil rings I would also check the oil inlets on the turbo make sure there are no cracks were oil could leak through keep am eye on engine oil level and check ur intake and pnuematic plumbing for substantial oil build up
i just started doin this, and also does anyone know which turbo is the one leaking?
changed the oil today to see if that would help, but i will know in a couple of day
