1 - 12 of 12 Posts
My pickup don't have the power that it should this is my second first gen and my first one had a lot more power than this one and it only had the fuel pump turned up a little and my new one has the pump turned up to almost run a way and a 40 horse fuel pin and a half turbo... I'm thinking injectors but I don't know. Any ideas will help thanks!
whats a 40 horse fuel pin and half turbo?
Maybe if you had a whole turbo?
Is it smoking cutting out not revving? What's the symptoms. Do you have a after market exhaust housing? If it's waste gated?
I meant a hx35 turbo and it's revving up and I have a 4 in straight pipe turbo back and it smokes a little when I get on it and I have an automatic transmission
Was the other truck a manual?
Sent using AutoGuide
Was the other truck a none inter cooled truck as well??
Most likely auto slipping
U got full travel on your throttle?
1 - 12 of 12 Posts
