I strongly suspect that no-A/C trucks were rare enough that Dodge would not have produced separate wiring harnesses. If that's the case, everything under the hood (compressor, condenser, drier, pressure sensors, etc) should be relatively bolt-on and plug-in from a donor truck. I don't believe non-A/C trucks got a different PCM (which controls the compressor). The dash side is, I think, going to be the hard part. At the very least your entire dash will have to come out of the truck to remove the airbox and add the evaporator -- It's unclear to me from the info I can find whether or not it's a different airbox entirely. You'll need to cut the firewall to run the refrigerant lines. You will almost certainly damage the dash in the process -- there are not a lot of 94-97 Ram dashes still completely intact after 20+ years in the sun, so that's gonna be a thing.
I'm with
@Antonm. It's a doable project, but challenging -- maybe too challenging to be worth it. More doable if you don't actually need the truck running and you can have stuff just sitting apart (and undriveable) while you do research and try to find parts. There's not a lot of non-A/C trucks out there, so finding pictures/info/help will be an issue, I think you're going to need to start taking stuff apart just to know what's there. On the bright side, I suspect non-A/C was a lot more common in the 1500s and the dash-side half should be identical to the 1500s.
Frankly... if you really need A/C, you better be getting this truck for an
amazing price because it's going to be a lot of effort to add it. If the price is merely good-to-fair, I'd say no and wait for another truck.
