The wait to start light in my truck has stopped working and the lift pump doesn't prime for 2 sec when I turn the ignition on, it also doesn't run for 20 sec when I bump the starter, but I have 20 psi of fp once truck is running.
I have seen the wts light delayed a couple of times in the past and the lift pump doesn't always prime when you first turn the key.
I checked my alternator for AC noise using one of mopar1973man videos on youtube and it showed 0.05 V I read its still within the normal range.
I measured the voltage going to the grid heather relays and it reads 4v with key off and 6v key on, it doesn't switch the relay on so the intake heater isn't working :confused013:
I am leaning towards a broken ECM any way to confirm this?
I also recently changed my CPS but the problem didn't start right after but a couple days later.
thanks for your help.
btw truck is a 1998.5 auto
