A TPS is only used on a later model 1st gen with an OD trans and a PCM.
Shift points are controlled by TV cable adjustment. I am not ure if your nonIC TV cable adjusts the same as a IC trans does. I'll let someone with a 727 tell you how to adjust your TV cable.
