1 - 18 of 18 Posts
Hey guys. Left work today and went over some railroad tracks and I noticed my speedo and tach went out. I then noticed my odometer was not working and my batteries were not charging. The truck still drove and I made it home. Got on here immediately. I’m going to start checking loose connections but I figured I’d start this thread hoping one of you guys knows exactly what the problem is. I’m thinking ESS…. Any help would be great. If I figure it out before then I will post. Thanks
Super Moderator
Check the ESS gap should be .050
Reactions: RollDUPwood
Super Moderator
It's ok i've used one many times, or a credit card I hear they are close.
Super Moderator
If I type in NO TACH NO SPEEDO and filter it for 94-98 almost all of the searches reference replacing ESS. So I have no idea.
But just type in no speedometer and see what the fixes are. The other problems could be the ESS.
Because the same non-logical guesses are rampant. Do any of them show the ESS fixing the speedometer?
The logical way to troubleshoot would be to determine what the speedometer and the tach have in common. That requires opening the factory service manual and searching for a common link. More than likely that common link is a ground.
Super Moderator
I would look for a single fix. It would be odd for more than one thing to go at the exact same time. Not impossible just unlikely
When I junked out my 97 I saved the wiring to reuse and there was numerous grounds that had up to 6 individual wires on a terminal.
Discussion Starter · #13 ·
Yes I have an FSM just didn’t have it with me yesterday. I’ll look through it after work. Also the ac compressor doesn’t kick on.
...Also the ac compressor doesn’t kick on.
Tach, charging, and AC compressor will be inoperative if there is no ESS signal. But as others said, that should not affect speedometer or odometer. As said above, look for something in common
Just going to copy/paste myself from a previous post lol. Do you get bulb checks (WTS, WIF, etc?) when you turn the key on?
If the alternator wasn't charging but you get a GEN light on the dash -- alternator bad.
No tach, no charging, but speedo works -- ESS issue.
Tach+charging, no speedo -- VSS issue.
No tach, no charging, no speedo, no bulb checks -- PCM is bad (Maybe not fried, maybe just power/ground issues)
Discussion Starter · #17 ·
No TACH, No ODO, No CHARGE, No SPEEDO, No AC COMPRESSOR, No WAIT TO START, No GEN LIGHT. I’ll be checking stuff when I get home. Thank you.
Discussion Starter · #18 ·
1 - 18 of 18 Posts
