smartys dont blow much smoke.
YouTube - crackercwboy 6.7 cummins smartyive got an 08 6.7 running smarty ive got dpf delete and egr delete has only blown heavy smoke once at 50 stomp on level 9 and all settings on level 2 i have a manual trans just curioes if its normal that its not blowing much smoke?
No stacking, dont want to blow a gasket. I was just playing around with it. I usally run #7 with hardly no smoke.if ur running level 8 are you stacking? im running manual and i know on the 5.9s they roll some coal
Holy cow Smarty 9 and mp8 at 100% do you drive like this all the time?? Do you have your head studs and tranny upgraded?? Do you drive with heavy foot or normal ?? Seems like lots of power!!!!?????:thumbsup::thumbsup::thumbsup::thumbsup:S67 don't blow much smoke, but if you think about it it just means its an efficient tuner. so rather then blowing the power out of your pipe you are just pushing it out the crank.
Even on mine #9 with the MP8 100% I don't get much smoke. The most I saw was on the dyno and it was not much.
being that I have the stock fuel system you have more power on level #7 with the MP8. But yeah I have ARP 625 studs. Normally I don't run the MP8, EGT's get a touch hotter and the power is just fine on #7. Need a bigger turbo, Stock tranny that is hurting with a Goerend TC.Holy cow Smarty 9 and mp8 at 100% do you drive like this all the time?? Do you have your head studs and tranny upgraded?? Do you drive with heavy foot or normal ?? Seems like lots of power!!!!?????:thumbsup::thumbsup::thumbsup::thumbsup:
And what settings do you run them on ?? Default ??:thumbsup::thumbsup:being that I have the stock fuel system you have more power on level #7 with the MP8. But yeah I have ARP 625 studs. Normally I don't run the MP8, EGT's get a touch hotter and the power is just fine on #7. Need a bigger turbo, Stock tranny that is hurting with a Goerend TC.
