1 - 12 of 12 Posts
i'm running edge/juice and afe stage 2 i have no response on the bottom end. even when i change the settings. the truck acts stock until i reach about 1800rpm then it takes off like a rocket. have a 6spd manual. even if build boost launch nothin. any advise?waiting for dpf
mp8 and dpf delete helped mine alot was the same as you, you have the hot unlock
Once you do the delete you will notice the differences.
i do not have the unlock code yet.figured i should wait until the engine could breath better! had a power stroke before and it had great response with edge i would like the same with the dodge.
sounds like you are in regen.
regen is not on.at least the edge says it's not on.
Discussion Starter #8
it is worse when it is in regen:
What are your low end settings at?
Are you sure your turbo is ok?
Discussion Starter #11
yeah it does have power don't get me wrong.just nothing like my powerstroke.the setting are on high/or best what ever it is. i have tried all settings and can't tell a difference.
i will have to agree with you somewhat on this one..i am used to crazy larry on my 06, and this one just doesnt have near the throttle response with all of my mods..but when you actually mash it, it will fly..
1 - 12 of 12 Posts
