21 - 28 of 28 Posts
Have you replaced the fuel outlet check valve? I believe your engine should have one. It's the banjo fitting where the fuel return attaches to the pump, creates backpressure in the injection pump to fill the chambers.
I don't remember it being a check valve, looks more like a banjo bolt with some small holes drilled into it. I have one laying around here somewhere.
I’m
pretty positive it has no check ball or valve just a small Orifice orifice and a screen to protect it.
I’m
I'll see if I can find that one I have, i'm with you on that.
My bad, 94 with the inline pump had the valve. Old brain....
That would be the OFV valve on the P Pump engine. That's ok if you've never had a VE pump then you wouldn't know.
21 - 28 of 28 Posts
