Well here is a couple of thing to check... Check for main fuel line crimped or squeezed together between the bedrails & tank or behind tank & frame.
Also check plastic quick connector at the top of the tank, remember you are not looking for a fuel leak here. you are most likely sucking air into the system some where. it is possiable it could have streached the line when you rolled it over a either broke the quick connector at the tank or at the very least messed up the o-ring
Hope this will help, let us know what you find
:thumbsup:
:thumbsup:
