When i first start my 99 24V Cummins i get no oil pressure for the first 5 seconds or so after its fired up.
Whats the deal is this normal?
Don't know if it's normal but my 97 does the same thing.
got a 98 12v does exactly the same thing 198,158 miles later :w:
my 91 does that too! Screwy sender maybe?
I worked on an 03 for a guy that was having the same type of issues ( but lasting a little longer) after beating my head against the wall for a while i decided to pull the oil pan. i found a crack on the oil suction tube where it bolts to the block. I replaced it and have had no further problems. Yours may be cracked or it may be loose. If it is loose it will also cause oil pressure issues.
Washington Chapter Pres.
As long as you get oil pressure within the first 10 seconds of the engine starting I wouldn't worry about it.
thanks guys!!
