1 - 20 of 62 Posts
Y'alls have any tricks for not making a mess when un screwing the filter and lowing it down to rest it on the trey? Seems like the last couple times once I unscrew it oil starts running down the filter and makes a little mess, and oil keeps driping from the filter housing... Nothing big but its enough that i have clean up after.
stick an old tshirt in the hole to rest the filter on...use a cap off tool. suggest youtube...many videos out there.
White Lightning
Let it sit for a couple hours before you you remove the filter.
This......can’t explain the process, but the engine actually seems to “siphon” some of the oil from the filter after a few hours.
If you’re removing it via the wheel well opening....a cap off tool would be best, as mentioned above.
thanks. ill try letting it set.. I use the cap on the filter when pulling it out of the wheel well..
Letting it set works well. I usually let it set overnight and drain it the next day. Never any issue.
The oil cools off and contracts.
08 Cummins
That's what I do. I get the engine up to temp and drain the oil. I let the truck sit for an hour or two before pulling the filter though and I'm able to drop it out without spilling any oil. There is normally about 3/8" of space at the top of the filter.
I drain the oil for about an hour then change the filter nothing spills I also use the capoff tool to drag it through that little opening that they made to small.
Once you get the filter loose, slide a gallon freezer bag over it and just loosen it until it drops into the bag.
Is it worth relocating the filter in the new trucks that you can't drop straight out the bottom?
No absolutely not. The filter is 100% perfectly fine right where it’s at. Don’t be a baby just use a grocery bag and change it like everyone else’s :p
Um ok, if I ever get a new truck I'll try not to be a baby about getting my hands dirty. LOL
Reactions: s10010001
Joe @ DDP Motorsports
I like the filter where it's at from the factory. Secured out of the way where it won't get ripped off by road debris.
1 - 20 of 62 Posts
