Is there a scanner that I can check Converter lockup with on a 48re (Like actual lockup pressure)?
I have verified ECM is sending converter lockup signal via Insight monitor, and also manually attempted to lock it up with a wire to ground on the tcc circuit wire. No lockup, no codes...
Need to Figure out if I have a bad TCC solenoid on the Valvebody or if its going to be something thats more fun to figure out. Have read it can be simple as filter or poss TIPM or an alternator. Doubt its the converter, but irt was locking up as it should perfectly and then one day like viola... no lockup
Pan was off 1200 miles ago and filter changed and fluid refreshed, noticed trans operating warmer than usual a couple days ago on the freeway, instead of 165 or so up in the 220s.. verified lockup signal being sent, but converter not locked.
Conveters not locking up in or out of tow mode etc.
Trans is built with Altos Kolenes +1 powerpacks, Transgo kit GM solenoid All billet sonax poistons actuators etc and billet I/O shafts. Billet converter. Rigid band billet strut and anchor etc.
SHifts great no other issues fluid looks good on stick.
Rreally dont want to blindly chase my ding dong... Any ideas?
