check your crank sensor if not that it might be the lockouts in your tranny
It could be the engine speed sensor. Did you actually find it and check it yet? It may just be loose or need to have the connector cleaned. It is on the front of the motor mounted just above the large main pulley.if i buy one from napa is that ok?
Could be the same reason the od isn't working, bad brake switch.any idea why my cruise is not working?
The ESS, no CPS on a 12 valve, is made by the same company from Cummins as Napa.in know on the fords its important that you buy a motorcraft part for the CPS
when choosing this part would any part store work?
or should i go mopar.
