1 - 12 of 12 Posts
Its been cold the past few nights (-25*F) and the day temps barely making it to 5*F. I go to use my truck last night and after i started it go to put on my headlights. Thats was a NO GO. cab lights, dash lights, parking lights and fogs all come on except the headlights themselves. Thought it was the bulbs, replaced them and... nothing. At work thinking about it right now, going to try replacing the switch and see if that works.
Any other suggestions?
Discussion Starter #2
so my girlfriend just tried my lights out, turns out the high beams work and lows DO NOT, also my blinkers do not work.
Just an update but still looking for some suggestions
still sounds like the switch in the column
ok, i had a problem like this and it was my headlight switch. Also see if there are any fuses or relays bad.
i had this problem in my old cummins and have this problem now in my current one, pull the headlight switch out and unplug it, look at the plastic box lookin deal with all the wires coming into it, there was one part melted on mine, so friday im replaceing that pig tail and the switch
Marble Crusher
agreed with the headlight switch had to replace the one on my 01 at work and it was doing the same thing.
-Jordan-
I had this exact problem, it was the combination switch in the steering column. it is the stalk on the left side of the steering column that controls the wipers/blinkers/hi-lo beam/flashers. part is available from advance auto, was about 60$, need some torx bits to get the plastic housing of the steering column off, and get the switch out. I just replaced mine, but I took my old one apart and found that where the contacts rest inside the switch for the low beams there was a corrosion buildup or a burn spot. cleaned it with a small piece of sandpaper and good to go.
Discussion Starter #8
whats wierd is that I tried it yesterday when i got home and all of a sudden the low beams work, my blinkers work (drivers side is a little fast) but it worked a few hours later then when my girlfriend tried.. Wierd Im going to take a look on friday my day off and try both switches.
Thanks guysfor the second opinions!
No that's exactly what mine did. If you cycle the switch a few times you should see that it can work and the next time not. Just pull your combo blinker switch take it apart you will see the burnt contact right away. Lil sandpaper and some dielectric grease and u be good to go.
Multifuntion switch on the collumn. Had the same prob to the t. Makes for a scary drive in the backwoods when it fails, dont ask me how i know.
i just replaced the headlight switch and the plasic peace with all the wires on it and it works fine now, any up dates? did ya get er fixed?
1 - 12 of 12 Posts
