Sounds like you have a leak, huh. If it is leaking that bad you should be able to find it easily. If the inside of your truck smels like a gym bag when it is on then bad news, ya gotta pull the dash (evaporator). If not trace all the lines and condenser radiator to feel adnd look for oil or hear the leak. If you can't find it load it up with a can of UV dye and enough freon to keep the compressor running at least until you get the dye circulated. Then use a black light in the dark to spot the bright yellow dye and the leak. Then all you have to do is fix it.
