1 - 20 of 71 Posts
so, what is the absolute most power a vp44 powered truck can make.
I am talking built bottom end, and like 13:1 comp ratio with boost over 100 psi......
is there a vp-44 that can handle that, or do you need a common rail or p-pump?
i tihnk that most people who plan on going that far with the performance go ahead and do the p-7100 pump conversion
Diesel South
gus @ Farmboys is doing 807hp on a monster pump on fuel only!! but im not sure but fuel only with an so or Hrvp i think it like 650 or 700! not sure though
Mark Ward
im sure with the mula and right parts you can get 900+ on a VP.
There is a guy out in Cali who has hit the Thousand HP mark But for it You will need Really BIG twins and alot of fuel like a monster pump or a hot rod pump.
the HRVP is not what u need for high horse, u need a Monster, the SO will make more power than the HRVP i believe...
Mike
It's got 12 Valves...
You can make big power on a VP truck but you need lot's of fuel, a monster VP would be a must...and a lot of :$::$::$: to make it happen.
You need a SIGMA it will blow away a p pump
I just read in one of my latest Diesel Power mags that SIGMA pumps are not made anymore and are hard to find and can be as much as $10,000. I think thats what it said, WOW can that be right? SON OF A!!!!!!!!!
Tech Specialist
yea but he is talking with a VP not sigma or P pump.
Re-read the last line of his post
"is there a vp-44 that can handle that, or do you need a common rail or p-pump? "
Not trying to be an a$$ just stating that he mentioned using a p-pump or common rail
Yeah Sigmas are not made anymore and they are expensive its what you pay to push all that fuel. But If you really got the :$::$::$::$: Columbus Diesel makes a all breand new billet design that can supply enough fuel for 2000hp now you would need the turbos to supply the air for it.
i was talking to highrollinmopar.. and no the sigma's arent made anymore and they were only produced in europe i think. atleast thats where curt haisley got his. from an old big rig in europe and yes they are like $10,000
Also I wanted to ask Everywhere I look it seems no one has even dynoed a Monster pump lets say on a stock truck to see how much of a difference it makes. OR really havent seen any numbers to the fact how much more it flows then a Hot Rod VP44 so it's all up in the air right now.
1 - 20 of 71 Posts
